testing G65
Old Jun 27, 2006 | 02:56 PM
KennyBradley's Avatar
New Member
Default testing G65
My car is a 2002 Audi a4 TDi 130hp.
Problem is I don't have a VAG-COM. I put my car to the local dealer who said he was getting a fault code indicating a short in the G65 sensor so he replaced it and advised I get the refrigerant recharged. Unfortunatley this didn't fix the problem and he was still getting the same fault code so he assumed the problem must be with the wiring to the G65 sensor but could be expensive to find.
So that is why I was trying to check the wiring myself.
Measuring the 3 wires On the sensor plug:
earth connection seems good
middle wire was reading 11v from the climate control unit? this sould be for sending the signal back?
I was getting no positive supply on the third terminal.
Can anyone offer any advice?
Cheers Kenny
Old Jun 27, 2006 | 03:20 PM
Chalfont's Avatar
Default Lots of Turbo knowledge here, but not much Turbo Diesel....
assuming whatever a G65 is exclusive to a TDi engine.
You're out of warranty so I'd try and find a good VW/Audi/Seat/Skoda (all the same really !) independent. I know of two in the Thames Valley area.
Old Jun 27, 2006 | 03:42 PM
Tgr_Clw's Avatar
AudiWorld Uber User
Yeah, unfortunately we were never offered Audi TDI engines in North America.
Old Jun 28, 2006 | 10:21 AM
New Member
Default Re: testing G65
Thanks for the reply guys.
The G65 sensor is the high pressure sensor on the air con system, I assumed it was common to al B6 A4's?. My car is stuck in econ mode so I'm not getting any air conditioning.
Unfortunatley my location limits me to where I can go for help. That's why I'm trying to look into it myself.
Cheers Kenny
Old Jun 29, 2006 | 12:58 PM
New Member
Default Problem solved
Looks like the problem's solved. There is a fuse for the power supply to the G65 sensor. That fuse must have blown when the old sensor shorted.
So problem is solved.
Thanks to Derek for your help.
Old Jun 30, 2006 | 05:47 PM
aandmaudi's Avatar
New Member
hi there my ECON button dosent want to turn off and there for isnt turning my compressor on, what became of your issue. Thank you
iestatic
S4 (B8 Platform) Discussion
20
Jul 15, 2022 09:43 PM
audiinnj
A4 (B8 Platform) Discussion
9
Dec 5, 2018 04:31 AM
BriGuy01-2.7T
37
Oct 22, 2015 08:04 AM
danfil
Sep 19, 2015 06:32 PM
