a4 crankshaft position sensor
Old 09-10-2011, 06:52 PM
vpinargote's Avatar
Default a4 crankshaft position sensor
Hey Guys,
Just had a question here, not sure how easy it is to answer, but my car is having issues staying on, got a P0321 error with the check engine light. Decided to buy the crankshaft sensor. Now by what I've seen in other posts, is the crankshaft sensor the same cable at the engine speed sensor??
I've seen sites referring crankshaft sensor as a engine speed sensor as well so I'm a bit confused. They state that the engine speed sensor is located near the oil filter in my car, which I've located, just need to know if that's the right cable I'm replacing.
Thanks
-Ramon
Old 09-10-2011, 09:40 PM
MaxD's Avatar
Default I think they're the same thing...
My A4 was having hard starts. I can't track down my VagCom report, but the error you have sounds the same.
I'm pretty sure Engine Speed Sensor (ESS) and Crank Position Sensor (CPS) are the same thing, one may be what they called it in earlier model years.
I followed this DIY and successfully replaced CPS. Problem went away.
Old 09-11-2011, 09:51 AM
vpinargote's Avatar
Hey MaxD,
Thanks for the response and the link, changed the sensor this morning and my car turned on with no problems!! Now unfortunately I'm not hearing an annoying rattling in the rear end of my car, almost by where the gas tank is located..guess that's another mystery that needs some solving.
-Ramon
Old 09-19-2011, 06:09 AM
lyleswk's Avatar
Rattle or whine? Rattle could be a broken exhaust hanger. Whine could be the fuel pump. Can you be more specific on the location?
Old 09-20-2011, 06:31 AM
vpinargote's Avatar
It sounded like a rattling sound by the rear passenger side, but strange enough after that first day, it stopped and haven't heard it since then. car is running good.
-Ramon
Old 09-20-2011, 09:20 AM
lyleswk's Avatar
Sounds like fuel pump. When is the last time you changed the fuel filter? It could be clogging up and causing the pump to work harder and be noisy which will eventually fail the pump.
Old 09-20-2011, 10:38 AM
Audiworld Basic Sponsor
ECS Tuning-Audi's Avatar
If you constantly run your fuel level down to E you can also risk over heating the pump.
The fuel is what cools the pump so if it's constantly getting too hot it will fail prematurely.
Jason
Old 09-28-2011, 04:34 PM
vpinargote's Avatar
I actually changed it like 3 weeks ago since it was never changed.
Old 09-28-2011, 04:35 PM
vpinargote's Avatar
Jason
Thanks for the info Jason, yeah I noticed I had that habit of driving my car til a quarter tank or so..I stopped.
Thanks
-Ramon
Old 09-30-2011, 01:05 PM
woofster's Avatar
Without hearing the actual sound, my guess would also be a clogged fuel filter.
Jim Castronova
04-13-2018 03:43 AM
costra
Q7 MK 1 Discussion
10-22-2017 11:02 AM
newa6er
04-14-2014 05:39 PM
donromani
14
10-13-2009 04:21 AM
Quick Reply: a4 crankshaft position sensor
