Battery drain, removed cigarette lighter fuse & all is good.
Old 06-11-2018, 11:43 AM
NS_Audi's Avatar
Default Battery drain, removed cigarette lighter fuse & all is good.
I have a 2005 Audi A4 Quattro 3.0l that I just bought a week ago. I realized that the cigarette lighter was not working on the drive home. Last night I remembered this about the cigarette lighter and went out and checked the fuse, it was blown. Today after driving around and so on my battery light came on. I couldn't understand why as belt was good, battery ok and Alt ok. Then I remembered putting the fuse in last night. I didn't think this would be related but I decided to check. I started the car and turned on as much electrical equipment as I could. The lights started to go dim and not recover. I pulled the fuse at this time and nothing happened. I then gave it a little bit of fuel and then all the lights came on bright and the battery light went off. Went for a drive and haven't had anymore issues.
Has anyone else had this type of issue? How can you fix it permanently and have your cigarette lighter outlet?
New to Audi as I have wanted one for a while now and finally pulled the trigger.
Old 06-12-2018, 07:43 AM
lyleswk's Avatar
My cigarette lighter doesn't work. Maybe this is why.
I had a similar problem with the radio draining the battery and just replaced it with a "donor" car. Maybe you can locate a "donor" car with a good lighter...
Old 06-12-2018, 11:02 AM
NS_Audi's Avatar
For sure. I was thinking of having the cigarette lighter connected with a Google switch so I can cut the power to it and when I need to plug something in I can just flip the switch. I have these small round inconspicuous ones that hide nicely.
I didn't drive it until today and only had to go about 2 kms and then stop and wait for the store to open. I had to wait 15 minutes but I had the car idle off with the radio on. When I came back out my car wouldn't start. I got a boost and just after it was boosted I had 2 lights come on, battery one and the ESP one. After about 2 minutes they both went off. I took it for a good half hour run on the highway in hopes to charge the battery. I haven't had anymore no starting issues as of yet. Crossing my fingers.
Old 06-13-2018, 04:50 AM
lyleswk's Avatar
ESP is typical when losing battery charge. The final reset is the steering angle sensor.
Well, goo luck and let us know how it goes. It has always been a pain in mine as I use the trunk / boot charge with a long cord to charge in the car.
Catamount90
11
06-19-2021 07:55 PM
red90q
10-14-2007 10:57 AM
JustinMarkVII
03-08-2005 08:11 AM
EXPetrush
11-11-2004 05:29 PM
zon
05-21-2003 06:38 PM
Quick Reply: Battery drain, removed cigarette lighter fuse & all is good.
