Is this what your OEM 1.8t manual trans mount looked like?
I recently ordered what I thought was an OEM style transmission mount for my 2002 1.8t manual. When I removed the old one, I was surprised to see that the one I received was quite different. As you can see, the OEM mount looks like it's damaged, but maybe it's not. There are pieces of rubber that look like they may have torn.
Original http://i108.photobucket.com/albums/n...e/IMG_7284.jpg Mine looks like this, but the rubber attached to the middle bolt hole connects to the outer diameter with 4 supports (like a + ) http://shop.oreillyauto.com/product_...g/anh/8999.jpg I'm hearing a lot more transmission noise with the new mount than the old, so maybe I should just move back to the OEM one if it isn't actually damaged. Can anyone confirm if it is, or if I just got the wrong mount? |
Originally Posted by psuaudi
(Post 23862038)
Original http://i108.photobucket.com/albums/n...e/IMG_7284.jpg Mine looks like this, but the rubber attached to the middle bolt hole connects to the outer diameter with 4 supports (like a + ) http://shop.oreillyauto.com/product_...g/anh/8999.jpg I'm hearing a lot more transmission noise with the new mount than the old, so maybe I should just move back to the OEM one if it isn't actually damaged. Can anyone confirm if it is, or if I just got the wrong mount? Where did you order it from? When I ordered mine(from 034 Motorsport) it was a little bit different, and yes it does vibrate more than the oem as it is made from a stronger rubber but it definitely made a difference. To answer your question mine looked kind of like your cracked one, therefor making a clunking noise. |
Also I hope you removed that gray rubber cover from the new Mount. here is a DIY(It's the one I used):
http://www.audigeeks.com/forums/index.php?topic=2785.0 |
I did. I installed it just fine after drilled a small hole for the peg on the top of the new mount.
I think the new mount is a little too strong for me though, and I'm going to try some different ones. How do you like your 034 motorsports? |
(Post 23869911)
