Wheel Offset!!! Please explain
Old Aug 20, 2002 | 01:38 PM
fshams's Avatar
FShams
Default Wheel Offset!!! Please explain
Folks, can someone explain the wheel offset in simple terms... I see ET35, ET37 and ET45... What does it really mean, compared to the factory wheels on the car..... Which one sits further out?
Old Aug 20, 2002 | 01:40 PM
SKareKrow's Avatar
The smaller numbers move further out. Oem offset is 35
Old Aug 20, 2002 | 02:26 PM
alpha.four's Avatar
New Member
Default Re: The smaller numbers move further out. Oem offset is 35
7.5J x 17" , ET45
8J x 17" , ET 35
7.5J x 17" , ET 43
8J x 18" , Et 43
All are 112/5 lugs
There are the specs for OEN Wheels Options on the 02 A4. As you can see the ET fluctuates according the wheel design.
Old Aug 20, 2002 | 02:40 PM
polar 1.8T's Avatar
New Member
Default Offset explanation..
Oem is 45mm offset on oem 17" 02 sport wheels I think, 16" 02 wheels were 42mm offset..if you were to put 10mm spacers on oem 17" sport wheels theyd give you a corrected offset of 35mm (45mm offset - 10mm for the spacer) giving it more 'poke'..a wider track, more clearance from the caliper and suspension than the original more 'sucked in' original 45mm offset. Say you were going to a 19x8.5" wheel, 35mm et is what youd need for clearance on that extra inch of wheel. a 8.5" wide wheel with a higher 45mm offset probably wouldnt clear the shocks, since it'd be too sucked in. If you went too low of an offset though it'd poke wheel/tire like a gocart and rub like crazy :-( check out the link for a more technical explanation..<ul><li><a href="http://www.tirerack.com/wheels/tech/offset.htm">http://www.tirerack.com/wheels/tech/offset.htm</a</li></ul>
rayjr13
10
Apr 12, 2016 04:43 PM
Monsoonenough
S4 (B8 Platform) Discussion
Oct 3, 2015 02:59 PM
sydnieme
Q3 Discussion
Sep 2, 2015 02:37 PM
Al_Bundy
Sep 2, 2015 07:24 AM
RCCurtis
Sep 1, 2015 03:09 PM
