woofpup - help removing interior door trim
First wanted to say thanks for posting all the removal how to's for the other interior pieces. Do you happen to have the same for the doors? (ie Bentley manual pics?)THANKS!
it's really easy...
for each door, start at the end the closer to the front of the car, "slide" your figgers underneath the trim and gently but firmly pull upwards and towards the inside of the car, this should unhook the first pin, once the first one is unhook just work you way towards the end of the trim, and in order to get it completly off you'll have to slightly turn the trim as the last "junction" with the door is a sort of hook...
hope that's clear enough... once you get the first one off, the other ones are going to be really easy... although make sure all the clips (metal part) stayed on the door, check the pin and of the trim, and just put back the clip if it came off...
that's how I did it on mine...
good luck...!
good luck...!
Cmmartin23
26
08-23-2016 04:44 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-11-2015 11:25 AM
ECS Tuning-Audi
09-10-2015 01:14 PM
ECS Tuning-Audi
09-10-2015 12:39 PM
ECS Tuning-Audi
09-10-2015 12:39 PM
