2006 A4 headlight warning light?
Anyone know the meaning of the the "warning light" which looks like a yellow headlight with a bent arrow on it? Came on this morning...can't find this one in the manual. It's displying in the info display, not as an idiot light. Diagnotics still show a nice green "OK".
Any ideas?
Any ideas?
Re: Adaptive headlight fault
Ah! Interesting. It came on at the *exact* same time I was passing (rapidly!) another car. Perhaps the sudden speed change and hitting a small bump (!) might have confused the system. Went out to the parking lot just now...warning light is gone.
Do you know of a good reference for these warnings?
I get it all the time, and the dealership won't fix it
I get it all the time. And everytime I clear the code out with a VAG-com cable, this comes back up every time.....
<img src="http://www.jdm****.com/TEMP/vagerror.jpg">
When I check the VAG-com logs after running a full diagnostics check, I always get this:
<b>
1 Fault Found:
02769 - Headlight Swivel Module; Left
003 - Mechanical Failure - Intermittent
</b>
Basically the dealership says they won't do anything about it because it's not a "category 3" issue, so I'm just fcuked with this problem that happens on most nights I drive the car <img src="http://hybrids.jp/forum/images/smilies/mad.gif">
<b>
1 Fault Found:
</b>
It's not, but here's a pic of it
<img src="http://www.jdm****.com/TEMP/errorlight.jpg">
I've been having this problem since October of last year and I made numerous posts about it with lots of info that I found (and from VAG). Basically my problem seems to be a malfunctioning mechanism in the driver side headlight assembly but it's not worth replacing in Audi's opinion.
