2007 Audi A4 2.0T Quattro automatic/ oil consumption / black exhaust
Hello there,
Hoping I can get some guidance as to what I might be facing with these issues.
I have recently purchased an A4 2T Quattro 2007, 63,000miles. It burned a quart of oil in 580 miles and I can't get the dealer to tell me if it is normal, they want to run an "oil consumption test".
I have read a few comments about the high oil consumption but nothing specific as to what is really normal for this cars.
There is also an issue with acceleration, going up hill from a stop position usually merging from an exit. Not always but most of the times I get a black smoke from the exhaust (if accelerating somewhat hard) until I get to the top of the hill and some rattling noise as well.
Interesting enough if I time it right (speed wise) I can get away from the same situation without the smoke.No engine light on or anything like that,the car runs great otherwise.
Any ideas or familiarity with these issues?
Something to worry about and waste a visit to the dealer?
Thanks!
Thanks!
I have read a few comments about the high oil consumption but nothing specific as to what is really normal for this car.
Hopefully this is your case.
Good Luck
Hi I have the same problem with the black smoke and now it has turned in a bigger issue when I can't accelerate properly lucky if I get to 35 going up a hill any clue whats wrong? audi a4 quattro 2.0
Hello there,
Thanks!
Thanks!
Have the dealer do the consumption test. The Audi book says that a 1000 miles per quart is considered within Audi's acceptable range. Our experience with a 24K miles cay was 1 quart every 1500miles. They all use oil regardless of what anyone says. It is the nature of the turbo to do so. 500 miles is no go.
frankdt
I have reserched the 2007 2.0 turbo oil consumption issue thoroughly, as my wife bought a 2007 A4 2.0 quattro CPO with 6,900 miles on it in 2009. The car now has 48,900 miles on it, with less than three months left on the CPO warranty.
There is no doubt Audi has a serious problem with several years of the 1.8 and 2.0 turbos. 2009 is apparently the worst,and the problem may be fixed by now. However, turbochargers on consumer cars are problematic, vs superchargers, as the turbo's bearings have hot exhaust on one side, and cold air on the other. Part of the overall fix for 2013 include an 8 speed auto gearbox, which limits the use of the turbo in the course of everyday driving. As in 1800 rpms at 70mph. Less turbo use, less opportunity for problems.
Anyway, Audi has produced so many of these engines, many with issues, others perhaps not. However, the cost to the corporation to "come clean" and admit a problem would be ruinous. Billions of $. As a result, they have what might be called a "squeaky wheel" program. Those who are in warranty and are vocal (but nice) about the issue, are more likely to received some sort of meaningful effort by Audi to fix it. Whether that be a ring job, valves, bearings, whatever. GM had a similr type of problem with the Olds Omega (and similar new fwd models) w/manual transmission. It was only years later that their "secret" warranty progam became public knowledge. I had my shifting gear and some gears changed 3 times in 10,000 mi.
Sadly, Audi has taken a similar tack. However, those who mention the widespread 'net coverage of the issue, and are under warranty will get some updates. But more importantly, Audii will do an oil consumption test in which they actually weigh the oil they put into the car, then have the customer return it after 1000KM (630 mi). Asumming one's car is still under some sort of warranty, the outcome will depend on the measured oil consumption by weight. Depending on the consumption, and that number appears to be 1qt/900 miles to reach the minimum hurdle for say, a ring job, with more work suggested if the consumption is higher, then Audi will take the car in and work on it.
This of course does not take care of potential lost resale value due to the consumption issue and the expensive fixes likely for downstream owners. Note that Toyota recently had to pay a $1 billion settlement to reimburse owners for lost resale value due to a throttle control issue common to one model.
The take-aways are 1) if you are in warranty, you probably want poor oil consumption in order to get a free fix while you can, and 2) the parts being used for the repair may not be any different than those originally put in the engine, and 3) really track that oil consumption carefully and 4) make (gracious) noise at the dealer.
For those out of warranty, try to find a class action lawsuit to join. Best of luck to all.
The dealer kept giving me the run around.i was dumping a quart every 800 miles just got progressively worse. all they kept saying is its Normal. hell i have a 12 year old mustang with 120k and it doesn't burn a drop. i Got rid of the car. sick of wondering if it is eating oil after a tank of gas.
Andy Gster
16
09-14-2007 10:05 AM
