A4 vacuum leak
I have a 2007 a4 2.0 quattro. Check engine light code says vacuum leak. I replaced the gas cap. What should I look for next?
T, welcome aboard! Can you get someone to scan the car with VCDS? It'll provide more specific info. "Vacuum leak" is very generic.
Originally Posted by sawyerauction@gmail.com
(Post 25213804)
after a gas fill up , do you get a 5 second delay ? like it takes few seconds to start the engine. ( just after the fill up, in the gas station) if yes, then its the purge valve. a cheap and fast fix good luck |
I have a 2007 A4 b7 with navigation. The screen is out, but everything works. I am assuming the nav works too.
I have heard that if the screen is out it needs a fuse.Where is this fuse located? |
[QUOTE=sawyerauction@gmail.com;25240662]I have a 2007 A4 b7 with navigation. The screen is out, but everything works. I am assuming the nav works too.
I have heard that if the screen is out it needs a fuse.Where is this fuse located? All I can find is location on a Q5. |
