A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
how would I find out if I got flashed with 90 octane or 93 octane revo program?
Old 07-27-2006, 07:29 PM
KEVIN97A4's Avatar
Default how would I find out if I got flashed with 90 octane or 93 octane revo program?
is there way to tell? I only fill up with 93 by the way.
Old 07-27-2006, 07:38 PM
LAS
LAS's Avatar
would it say on the purchase receipt?
Old 07-27-2006, 07:52 PM
Tomasz@Startup's Avatar
Default Programs are the same, so this is not possible.
You could get the Select SPS or Select Plus and change between 91 and 93 Octane settings yourself. With Select Plus you could even write your own program for 94 or 100 Octane gas.
Having said that, your dealer would be able to tell what the Revo settings are - 91 Octane or 93 Octane settings. For 93 Octane they should be Boost - 6, Timing - 5, and Fueling -9.
IMHO upping boost is pontless, as the small KO3 can not make any more. Upping timing can deliver additional benefits depending on gas, ambient temperature, and the car. (This assumes stock car.)
If you live around Seattle, come over and I will check it out.
Old 07-27-2006, 08:19 PM
KEVIN97A4's Avatar
lol well since when does the receipt mean thats what you got and no it just sais flash
Old 07-27-2006, 08:20 PM
KEVIN97A4's Avatar
what would happen if it's on 91 settings and i'm running 93 octane?
Old 07-27-2006, 08:24 PM
bhvrdr's Avatar
Default Nothing bad at all. Perhaps not even a noticeable difference. Worst case...
Is a 5hp loss or so. Just have them check. The worse situation would be running 93 settings on 91 octane but Revo is very safe with timing and even that wouldnt likely cause you eminent danger. cheers! Mike
Old 07-27-2006, 08:35 PM
Default You would be giving up few horses...
Is there somethign wrong, or something does not feel right? You can post or e-mail me if you prefer.
Old 07-27-2006, 08:37 PM
KEVIN97A4's Avatar
Default well it's just that maybe I got used to the power......
just wondering if i'm getting all the advertised power of the flash. I have a tip and the cars does pull hard from 3-6k. I guess I need to do a few 0-60 runs with a stop watch or run a car who's 0-60 is close to what my car should be doing now.
Old 07-28-2006, 01:35 AM
crew219's Avatar
Default Actually Revo says:
91 octane
Timing: 3
Boost: 5
Fueling: 9
93 octane
Timing: 5
Boost: 7
Fueling: 9
But obviously there are adjustments available for modifications + regional fuel differences.
Dave
Old 07-28-2006, 07:02 AM
For A4?
Quick Reply: how would I find out if I got flashed with 90 octane or 93 octane revo program?
