A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
What’s this line connect to?
Old 03-27-2021, 05:14 PM
Krashdog's Avatar
Default What’s this line connect to?
Howdy, first post here.
I just found myself in an 05 a4 2.0
The previous owner had started removing the from clip to replace a water pump.
I finished that today, timing belt and water pump went on just fine.
she starts and drives but has a few goblins I need to fix.
one of which is this hose. I can’t for the life of me figure out where it connects.
Here’s the forward connection
driver side, hard line that connects to soft rubber
any insight would be greatly appreciated.
Old 03-28-2021, 02:38 AM
Hayabusafalcon's Avatar
Krash: I believe it to be a sensor line that connects to the brake booster circuit. See attached pic. Unfortunately it appears to be broken off the main fitting. That plastic crap! Geez.
Good luck, Haya....
Edit: I found the cheapest available on Parts Geek $53 but a salvaged one could be had for a few dollars I'm sure. Check out your local LKQ pick a part yard.
https://www.partsgeek.com/gbproducts...oaAqr2EALw_wcB
Krashdog (03-28-2021)
Old 03-28-2021, 08:32 AM
Krashdog's Avatar
Thanks, I really appreciate it.
Old 03-28-2021, 02:47 PM
Krashdog's Avatar
Confirmed yes, the plastic nipple is broken off the bottom. I’ll Oder a replacement
Huskerbob
16
03-06-2012 02:27 PM
ChronoGN
06-16-2009 11:16 AM
CMS4
08-10-2006 10:59 AM
luvmyquattro
11
10-16-2002 06:03 PM
DK
01-16-2001 08:26 AM
Quick Reply: What’s this line connect to?
