A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Engine Oil Flashes
Old 08-07-2018, 10:58 PM
Default Engine Oil Flashes
Car suddenly came to a stop when driving. attempt to start fails as vehicles tries to start but will not, then engine oil light begins to flash
Please what is wrong. My Local mechanic says the engine oil pump have packed up
Lesson is offline
Old 08-07-2018, 11:31 PM
the car is Audi A6, 5V, V6, 2.4 Automatic Transmission 1998model .
The local mechanic said the Car is failing compression. Checked fuel line. there is supply to the engine. battery meter is a little above 12volts.
Please i need help pls. the engine oil i use for servicing the car is the recommended engine spec 5w 40.
thank you very much for the assistance.
Lesson
Lesson is offline
Old 08-08-2018, 03:13 AM
uberwgn's Avatar
Lesson, do you know how many miles are on the car?
uberwgn is offline
Old 08-08-2018, 03:24 AM
Miles on the car is about two hundred and thirty thousand miles (230,0000)
Thank you.
Lesson is offline
Old 08-08-2018, 03:49 AM
uberwgn's Avatar
Rubber timing belt or timing chain? How long have you owned this car? Do you know the history?
uberwgn is offline
Old 08-08-2018, 03:59 AM
uberwgn's Avatar
In general, if the oil level reads full, and the light still comes on and is flashing, you either have a clogged or failed oil pump or sludged up scenario. The sensor could be bad, they certainly do fail. There is a typically a loud, annoying buzzer when all of this occurs. The car 'suddenly came to a stop' would carry deep meaning for me.
uberwgn is offline
Old 08-20-2018, 08:52 AM
Thanks alot for your concern friend. i was hearing a kind of rattling noise before the packup of the engine.
My mechanic came and install another engine. he detected that that the gaskete was bad. the engine now jumped timing.
he installed a 2.7litre engine to replace the previous 2.4 engine.
Car is running fine.
Cost some cash.
thank you all for your support.
Regards.
Lesson\.
Lesson is offline
crabb143
12-07-2012 06:38 PM
stevemac00
9
12-15-2009 07:02 AM
namjachoi
03-29-2009 12:50 PM
mpradeep
Audi 100 / A6 (C4 Platform)
08-20-2005 09:04 AM
vladc77
08-01-2002 11:26 PM
Quick Reply: Engine Oil Flashes
