Just curious
Re: Just curious
The B5 Passat was related to the B5 A4, as was the A6 from the same period. It had a longitudinal drivetrain like an A4.
The new Passat is based on a stretched and widened Mk V Jetta chassis. It has a unique floorpan and suspension components, but most of the bolt-on systems (electrical, HVAC, etc.) are common with the Jetta. It has a transverse drivetrain, and unlike the previous Passat the V6 is a narrow-V engine -- like a VR6.
The previous generation Passat shared platforms with the B6 A4
In fact, it shared a great deal of things, not just the platform.
The new Passat (as someone below stated already) is based on a stretched new Jetta platform and shares almost nothing, save the 2.0T engine in the 4 cyl models, (but mounted transversely) with the B7 A4.
I'm sure it's the B6. I cross-shopped both '02 models before buying a new B6 in 2002
The cars were, virtually identical.
The differences for the 4 cyl models were in trim, tranny, amenities and service only.
Naturally, the Audi was MUCH nicer. It was also 4 grand more.
B5 Passat = B5 A4
The similar features may have continued after the B6 A4 was introduced, as it does even today.
But if you climbed under both B5's you'd find identical engines, suspensions & transmissions. Those commonalities ended when the B6 A4 came out in 2002, as the Passat continued to use the old platform until the '06 model year.
