A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Need A/C experts - ECON button
Old 04-26-2018, 03:09 PM
svennorske's Avatar
Default Need A/C experts - ECON button
2006 Audi A4 Avant 2.0T Quattro
1. ECON button starts to intermittently turn on (effectively turning AC on/off). Eventually gets stuck on.
2. Code 00819 indicates Pressure Switch. Shop replaces switch and charges system.
3. Next day ECON is back to flashing on/off. Shop then replaces switch, still no fix. Had replace switch a second time just to be sure, still no fix.
4. The shop was able to observe the system pressure spiking when the ECON button comes on. He thought it could be the computer, but I'm not sure if he meant the actual ECU or something else? I'm not sure what controls this.
5. So changed out Climate Control Unit in-car to a known working unit, still no fix.
Loads of money spent 'diagnosing' with no fix. Could it simply be the compressor? Is there a way to actually test the compressor? I'm at my wits end...
Old 08-16-2019, 12:20 AM
Kchoul's Avatar
Had exactly the same problem (points 1-4), however, refused to have the climate control unit changed even though it was suggested by the shop, and even a specialized a/c repair shop recommended it as the most probable cause. I insisted on cleaning the a/c refrigerant circuit first which they didn't want to do initially due to the low mileage, approx. 80k miles. My gut was telling me the circuit could somehow be clogging, causing the pressure spikes and damaging the pressure switch. And to everyone's surprise the cleaning worked perfectly, no problem with a/c since then. Both the a/c control unit and the compressor are OK.
NOLA TT
12
07-18-2008 07:33 PM
laxman1100
04-11-2008 09:44 AM
RPG_99
07-05-2007 08:05 AM
Coolme
07-22-2006 02:58 PM
gerlicher
04-08-2006 01:55 PM
Quick Reply: Need A/C experts - ECON button
