A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Neuspeed Sport lowering Springs
Old 11-06-2005, 08:50 PM
New Member
JamesWatkins's Avatar
Default Neuspeed Sport lowering Springs
I am considering getting lowering springs on my A4 since in its stock state could be confused for an Allroad. Will it rub? Will they help the car handle better?
Old 11-07-2005, 04:34 AM
New Member
OceanBlueUSP's Avatar
Default Maybe you should try...
If your car is that high (Allroad-ish) I will assume you have the non-sport suspension. If all you get is lowering springs you will have dampers that are mismatched and your ride will suffer. Consider getting a good shock/ damper combination. Ecs tuning sells an H&R (iirc) and bilstein combo, and that is frequently mentioned as a quality setup. I do not believe that there were major suspension changes from the B6 to the B7, so that should open up more available parts for you.
Good luck,
Randy
Old 11-07-2005, 04:48 AM
New Member
s130turbo's Avatar
Default not true!!!
If you stick to a spring with a mild drop and rates, you will be fine. I found myself in this exact scenario, and got Eibach Pro Kit. The drop, for me, is perfect, and the ride has not suffered one single bit.
B6 and B7 springs are interchangeable BTW
Old 11-07-2005, 08:31 AM
New Member
Default Are the sway bars interchangable too?
I hope they are
Old 11-07-2005, 11:28 AM
Junior Member
FCastigl's Avatar
yes
Old 11-07-2005, 10:10 PM
New Member
Default Re: yes
Anyone here have any experience with after market sway bars on the B7? Feedback is greatly appreciated.
Lil Tiger
A4 allroad (B8 Platform) Discussion
10-21-2020 02:23 PM
Dudealicious
Q5/SQ5 MKI (8R) Discussion
09-12-2015 03:51 PM
S4intheOC
09-08-2015 12:12 AM
kclee1st
09-05-2015 09:35 PM
Dudealicious
11
09-05-2015 08:58 AM
Quick Reply: Neuspeed Sport lowering Springs
