Newbie Q: What's difference between Multitronic and Triptronic? - AudiWorld Forums
Go Back  AudiWorld Forums > Audi Models > Audi A4 > A4 (B7 Platform) Discussion
Reload this Page > Newbie Q: What's difference between Multitronic and Triptronic?
A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Sponsored by:
Sponsored by:
Old 08-12-2016, 10:12 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B7) Transmission Guides
Print Wikipost
Old 04-19-2005, 05:50 PM
New Member
Default Newbie Q: What's difference between Multitronic and Triptronic?
I know the Triptronic is on the Q, and the Multi on the CVT.
Now what's the difference?
Seems a bit hard to find this answer.
Thanks!
Jim
chezchez is offline
Old 04-20-2005, 12:11 AM
Default Re: Newbie Q: What's difference between Multitronic and Triptronic?
Tiptronic sorta refers to the shift *** itself inside the car. This shifter allows you to shift the gear manually. Non-multitronic cars have the "official" Tiptronic transmission, and the CVT models use the same Tiptronic shifter, but without the gears. It's just all a losely used term.
SFV A4 is offline
Old 04-20-2005, 09:14 AM
New Member
Default Multitronic (CVT) with the new "S" mode on the shifter is GREAT... Runs each shift point almost up
to redline and then upshifts like a normal non-cvt automatic... Opterates like a 6 speed auto... Very cool but probably will get you 11-15 mpg if left in that mode very long... Think I might be in "S" mode A LOT!
skipatola is offline
Old 04-20-2005, 09:54 AM
Default Multi-tronic is a CVT continuously variable transmission
It can be set so that it simulates gears, but that is actually the least efficient (both for economy and acceleration) from what I understand. The whole point of gearing and having more than 1 is to get the engine to a rpm range that is best for what is being called on at the moment, whether lazy cruising or foot to the floor acceleration.
The CVT can leave the engine at essentially the same rpm and just chnage the gearing around that. So if the car accelerates best at say 5500 rpm it could just zing the engine up to that speed and then allow the gearing to change as the car accelerates. The S mode will probably be slower although it may feel faster.
joxer is offline
Old 04-20-2005, 12:20 PM
New Member
"S" mode feels better even though "flooring it" in "D" may be faster... I likey "S"...
Old 04-20-2005, 02:06 PM
Tiptronic is a conventional automatic transmission -- in the Audi case with 6 forward gears. The shifts are able to be felt, the engine speed climbs in first gear then drops when second gear is engaged and so on.
Continuously Variable Transmission appears to have no distinct shift points and the engine speed appears (and does, mostly) rise in a linear fashion rather than the Tiptronic "stair step" fashion.
CVT, thus far only works in FWD Audis. Tiptronic works in quattros (and would work in FWD cars if Audi for some reason chose to sell them that way -- as far as I know, they don't.)
CVT transmissions are said to "equal" manual transmissions in acceleration and economy -- Tiptronic transmissions generally achieve poorer fuel milage and acceleration (apples to apples).
Manufacturers attempt to offset the traditional automatic transmissions drawbacks (generally) by having cars so equipped come with a shorter final drive ratio. The effect of this is to quicken acceleration but at the cost of higher engine speeds which decreases fuel economy.
The holy grail for the time being appears as if it will be a fully automatic dual clutch manual transmission (Audi calls theirs a DSG).
Frankly, with my personal experience with Tiptronics in the following order: 1 A8, 1 A6 2.8 and 2 A6 4.2's, I would prefer not to ever have to deal with the "wall of jello" feeling that the tiptronic equipped Audis seem to demonstrate -- some call it Tip lag, or drive by wire lag -- hell I dunno, it makes the car lurch and damn near stall and can scare the crap out of you when you are entering an intersection after a rolling stop (when the light has just changed) and you depress the pedal and "nothing happens" for 1.5 seconds -- your reaction is to floor the dang thing and then it "catches its wind" and the full force of an Audi V8 LURCHES and LEAPS forward like a rabbit with a hot poker stuck up where the sun don't shine.
Unfortunately, Audi has chosen to force Tiptronics on some of its customers. Hopefully the promised 6speed manual or DSG will be made available on the A4 3.2's sooner rather than later.
While I "got around" the Tip-lag situation by a DAILY reprogramming of the transmission (pretty simple to do, really), it just seemed that a $71,000 car (my A8) shouldn't need to be reprogrammed every damn time I got behind the wheel.
Where was I?
Anyway, hope this helps. If possible, at this point of inflection, get the manual and grin all the time you are behind the wheel.
markcincinnati is offline
Old 04-20-2005, 03:01 PM
New Member
Default Very interesting!
Now THAT is a informative post! Thanks a lot.
So my "lowly" CVT is much better than the Tip on the Qs eh? HUmm, cool.
chezchez is offline
Old 04-20-2005, 08:32 PM
Default Our CVT's are losely referred to as Tiptronics...
because we have the option of manually shifting through the fake gears. The term "Tiptronic" originated from an automatic transmission that allowed you to shift gears manually. The CVT does just that, except they are fake gears built in. And you shouldn't think of the CVT as lowly. It is advanced technology and provides an ideal blend of performance and efficiency.
SFV A4 is offline
Old 04-22-2005, 01:50 PM
The MultiTronic CVT is NOT AT ALL "Lowly!"
kirk zuraek
18
10-30-2003 05:05 PM
mustbeaudi
Wheels & Tires Discussion
10-21-2003 06:52 AM
gristopher
01-27-2003 11:41 AM
Via A4
08-23-2001 08:52 PM
Cole 2.8Q
04-03-2001 07:26 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
