A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Oil leak after head rebuild.. HELP
Old 04-28-2017, 08:25 AM
Dwrich21's Avatar
Default Oil leak after head rebuild.. HELP
2008 A4 Quattro 2.0T FSI
Rebuilt cylinder head and all is good now except for now there is a nasty oil leak at the rear of head. Seems to "spray" out all over the firewall and cat converter only when driving. Can't tell if it leaks at idle though. Oil found around timing chain cover, HPFP, engine cover where the most rear cover mount is. Cam/timing chain cover is new. I have no idea where this leak is coming from any ideas?
Old 04-28-2017, 08:28 AM
Dwrich21's Avatar
Default Edit
i meant the cam chain cover gasket is new
Old 05-01-2017, 08:06 AM
Dwrich21's Avatar
It ended up being the timing chain cover gasket folded when I redid the cam bearing cap. Replacing the gasket again should fix it. Thanks for the help..
jseklund
10-13-2015 11:31 AM
ColleenAllroad4.2
4.2 V8 Discussion
11-24-2008 06:21 AM
HZach
03-01-2004 07:50 AM
MissJennifer
12-27-2000 04:12 PM
Quick Reply: Oil leak after head rebuild.. HELP
