A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
optimal power shift points for 2.0t engine (with or without "chipping")
Old 05-08-2006, 11:29 AM
teaberry's Avatar
Default optimal power shift points for 2.0t engine (with or without "chipping")
I know the 2.0t engines allow higher rev-limit compared to the 1.8t engine and its also obvious that unlike N/A high-rev engines, there's no sense in going to the redline to get the most out of our engines.
I was wondering if anyone has done any "scientific" experimentation of what is a good point to shift at what gear (probably varies by different tuner like APR, GIAC, Neuspeed, etc)? I'm sure a dyno chart would probably help but I was just curious as I saw the article on Audiworld main page of the engine. It looks like torque curve starts declining after 5k rpm and hp a little after 6k rpm. Any thoughts?
Old 05-08-2006, 04:27 PM
New Member
Suba4's Avatar
Default Re: optimal power shift points for 2.0t engine (with or without "chipping")
I worked up a spreadsheet for this. It plots torque at the wheels vs road speed. In 1, 2, and 3, shift at redline: 34, 62, and 90 MPH.
Into 5th at 122, and 6th at 150 (after you remove the limiter, on that 1 mile downhill run...).
Old 05-08-2006, 04:34 PM
New Member
gtifrank69's Avatar
I take my car to 7k all the time.
New Member
Suba4's Avatar
Default Heres the graph
http://pictureposter.audiworld.com/94662/a4hp.jpg
Old 05-08-2006, 07:00 PM
bhvrdr's Avatar
Default Here's a dyno of stock and chipped to help you...
<img src="http://www.mjbmotorsport.com/sitebuildercontent/sitebuilderpictures/Stock-APRDyno-1.jpg">
Old 05-08-2006, 08:47 PM
John Stahmann's Avatar
Default From what i've heard, and felt short-shifting this engine is best
Shifting at or around 5000 rpm keeps you in ideal torque range. This 2.0T engine has a lot of torque down low and if you wind it out to redline you miss much of the power band.
Try it out.
Old 05-09-2006, 01:26 PM
Mr. Head's Avatar
Default Here's what you need to do...
<img src="http://pictureposter.audiworld.com/45027/shiftpoints.1.jpg">
I cant seem to access ross tech's site to refrence the tutorial on logging the data required and the calculations required to come up with this plot...
However, The spreadsheet calculates your acceleration and that is the curve you relate your shift point plot to.
Where the two acceleration curves meet, that is your optimum shift point due to it being the highest acceleration that that gear will give you up to the next.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2360228.phtml">https://forums.audiworld.com/a4/msgs/2360228.phtml</a</li></ul>
07-28-2005 02:41 AM
prototypeA4(Tom)
04-01-2005 04:14 AM
A4Driver
14
05-23-2002 09:13 PM
Audi_in_Van
05-05-2002 09:58 AM
Quick Reply: optimal power shift points for 2.0t engine (with or without "chipping")
