Selective unlocking, question for VAG-COM users
I am one of those, who want to have selective unlocking on my B7, but because it is European model, i don´t have it. If i just make recoding by add +4, it makes strange things, car is not possible to lock etc. I thing there must be something else what i should do. I thing that is necessary change chanel 61. Can you tell me, what nr. you have in chanel 61 on B7 US model? I´ve got nr. 2. Thanks.
Re: You should probably break down the number you have then make the necessary changes
I see you probably do not understand me, so i have central locking ECU code 7024 and no selective unlocking, if i add +4 it is 7028, ECU accepted the code, but it doesn´t work, so i think, there is another code which should be changed. I think that could be chanel 61, in chanel 62 there are coded diferent options (sunroof open/close, windows down/ up via remote, etc.). So i asking for number you have saved in chanel 61 in central locking ECU 46. Thanks.
If the B7 codes are similar to the B6, you should be looking and modifying channel 46 Central Convenience, NOT channel 61 or 62. Where did you get these channels?
See for more info:
http://www.ross-tech.com/vag-com/cars/audiB6.htmlhttp://www.ross-tech.com/vag-com/cars/audiB6.html
See for more info:
N'Syncro
33
02-16-2020 03:12 PM
scottnybottny
09-23-2017 06:28 AM
shabz
A4 (B7 Platform) Discussion
09-05-2015 12:34 PM
