StartupRacing B7 A4 2.0T Project is starting...
<center><img src="http://www.startupracing.com/images/Projects/OZSLRear.jpg"></center><p>
Quartz Gray 2006 A4 2.0T, loaded manual car w/o S-Line.
Completed mods:
19" OZ Superleggera with 245-35-19 tires (245 is the right width for the B7 chasis)
Upcoming mods:
Vibrant exhaust
Vogtland coilovers
Short Shifter
Of course this all will be documented using a nice Canon camera<ul><li><a href="http://www.startupracing.com/Projects.htm">Link to StartupRacing Project Cars</a></li></ul>
Completed mods:
Upcoming mods:
Vibrant exhaust
Vogtland coilovers
Short Shifter
235/35/19 is the closest to stock diamteter using a wheel calculator but as long as you don't use...
to aggressive of offsets, a 245 can fit. Tirerack screwed up and listed the 245/35 as the replacement size but it is actually the same for the B6 at the 235/35/19 as the chasis is actually the same 8E chasis. cheers! Mike
Rub? I have no clue why they would... plenty of room.
I guess depends how much lower they are. There are few mictures on the web.
But I will add a bunch to the gallery later.
With a 245, it is hit or miss depending on offset, amount dropped and the tire manufacturer...
as PP S03 tires can run almost a half inch wider than a Falken in the same 245 size so to be safe to fit about any 245 with a decent drop i'd stay at et35 or greater. cheers! mike
audiringpwr
Wheels & Tires Discussion
08-04-2006 09:14 PM
audiringpwr
07-31-2006 06:14 PM
Tomasz@Startup
05-03-2006 08:38 AM
SP (oenophile)
05-18-2005 10:10 AM
