Trunk Bike Rack
Trunk Bike Rack
Does anybody have experience using a trunk bike rack on an 08 A4? I'm thinking about getting the 3 bike Saris unit. Its cheaper and looks a lot easier to use than a roof rack, but I'm concerned it might damage the trunk or loosen the trunk mounting points.
Thanks
Thanks
I've had friends in the past use trunk mounted bike racks and its damaged the paint on the trunk.
We have bike roof racks available below.
Click HERE to order or for more information.
Let me know if you have any questions.
Jason
Jason
I bought a Thule Clip On last week for my B7 Avant.
I did a 500km trip with 2 bikes....
To be honest, it seems a lot of weight for the rear door.
I started my trip with 120km/h but after first hour i increased to 160km/h
I have done some stops to check bikes..... everything was fine, solid.
It was first trip and i cannot comment on paint damage, but mine after this trip is ok, no sign at all.
Clip on has protective rubber.
My return was on rain. Again solid... the only thing my bikes had a 3 hour high pressure washing and no oil left on the discs.
Last thing car width increases by aprox. 20cms on each side. Look after on narrow passes.
I work in a bike shop and sell both kinds of racks.
The roof rack is by far more stable, but it is relatively permanent as compared to a trunk rack that you put on and take off at will, and about 3-5x more expensive.
I personally dont want the look of a roof rack on my A4, so I would probably go with a trunk rack. We carry a bunch of models and brands, but I like the Saris Bones racks. They adjust easily, are light weight, and hold your bike securely. The rubber feet are non-marring and grip the surface of your trunk well. Messing up your paint usually comes from racks that shift or move around...the Bones are pretty solid.
Or, do what I do...i relegate my wifes car to be the "bike rack" car and have a yakima rack on that!
tow hitch
If you don't want to get the roof rack, think about a tow hitch. I would not recommend a trunk rack. i had a Yakima rack that i put ona different car and the weight of the bikes and the rack put dents and ruined the paint.
Not only do you get a more secure system, you get a more versatile system too that can be used for other purposes including; towing a small holiday-type luggage trailer or small utility trailer for those trips to the big-box stores. Saved delivery fees will help pay for the tow hitch in the long-run.
