Vibration when turing after CO installed.
05.5 A4 Quattro 6MT (30k miles).
About 3 weeks ago myself and a few others installed a set of KW V1's. At the same time I put on a set of RS4 reps (18x8, tire size 225/40/18). I also put on spacers (8mm front, 12.5mm rear, both hub-centric).
Now I am getting a vibration in the steering wheel when making a gradual right hand turn at 30mph+. I get it when making a left turn as well, just not as bad. It only vibrates when the turn is gradual, not on hard turns.
I had the tires/wheels road-forced, and had them re-balanced yesterday, I had a front and a rear a half an ounce off. So while that did clear up straight line vibrations at 60ish mph, did not do much for the turning vibration.
I also had the dealer do an alignment (which I do not think they did a good job, I will post the sheet below).
So far I have removed the spacers (no change). Inspect my TRE's (they look ok, but I am not an expert). I am not slammed by any means, I will check again but I am at about 25 1/2" all the way around.
I do need the clean the hubs with a wire brush, but other than that I am at a loss and seriously .
Any help/advice where to look, what to look for would be amazing.
Breitling
16
10-22-2005 05:45 PM
1 Mean TT
09-21-2005 10:53 AM
BukkakeRocky
07-20-2001 12:46 PM
