2009 A4 B8: Nut versions for securing track control link and guide link
Hi - I'm replacing all suspension arms + shock. Manual says that different Nut versions for securing track control link and guide link - need to be tightened to different torques. Description given is and 2 images or a nut attached to a washer -A- and a nut with a washer that is attached to the nut but can rotate -B-:
i) Hexagon flange nut -A- (M12) width
across flats: 21 mm
Tightening torque: 145 Nm
ii) Hexagon nut with washer -B- (M12)
width across flats: 18 mm
Tightening torque: 110 Nm
iii) Hexagon nut with washer -B- (M12)
width across flats: 21 mm
Tightening torque: 120 Nm
iv) Hexagon nut with washer -B- (M14)
Tightening torque: 140 Nm
But i dont't fully understand their description as the nut is an M18 (i.e. 18mm diameter) and I don't understand what they mean about 'width across flats' as the numbers they give correspond to no dimension that I can see on the nut that I'm using.
Any one enlighten me please ?
Thank you,
Gabriel
across flats: 21 mm
Thank you,
Gabriel
My service manual copy uses different wording. It appears 18mm and 21mm refers to the socket size used for the M12 combi nut So I'd guess you'd use 110Nm.
Zumkopf
10-15-2008 11:24 AM
Moneytree26
12-07-2003 11:59 AM
cmRobin21
10-05-2001 09:44 AM
