2010 A4 2.0TDI vibration problem near 40km/h @ 1100 ROM
My 2010 CVT A4 vibrates pretty significantly when driving near 40km/h @1100 RPM, strangely the vibration goes away if you accelerate fast (above 1100 RPM), but the vibration comes back if you keep your speed steady around 40. There is no such issue if you are stationary and rev the engine around 1100RPM.
The vibration can be heard in the cabin and it makes a Da Da Da Da noise and can be felt through the gear shifter.
The car can also be quite shaky when going into reverse, it was actually fine and a common issue for this car but if you reverse uphill the car is just reluctant to go, you have to give it a lot of gas.
The car has 11K kms
Can someone tell me if this is a Multitronic issue or maybe engine and tranny mount?
Huge thanks
The car has 11K kms
Huge thanks
rotate your tires..
Is it speed dependent or engine load dependent? If it only happens around 40km/h its likely something on the drivetrain (tires/brakes/axles/suspension/etc), if it happens in all gears around 1100rpm regardless of speed it'll be something related to engine (fueling/mounts/etc)
rotate your tires..
Suspension is in excellent shape - shocks is all good.
