Audi b&o concert dead screen dead radio.
I have just purchased an A4 s line with b&o concert.
apparently it was working according to the dealer.
ive checked front 20 amp mmi fuse(ok) head unit fuse(ok) and rear luggage space fuse panel mmi(blown)radio tuner(blown) and reversing camera (blown) I’ve replaced all fuses but still dead.
The car was started with a booster which I’ve read a power spike can do this.I have tried pulling the 20 amp fuse for 15/20 seconds as I’ve also seen this suggested.
running out of ideas now,does anyone have any suggestions please or similar situations which may help.
I bought the car at the right price and was aware of the mmi issue,I could take it to Audi,but would rather have the satisfaction of fixing it myself and then be able to offer help forums as well.
None
The car is going in for mot Wednesday,the mechanic is going to run a diagnostic,I assume it’s a vag diagnostic,if not I have some else who has a vag diognostic,but that will have to wait as I’ll be out of the country next week,if you can wait I’ll let you know,hopefully Wednesday I may have an answer.
Let's hope it's a quick fix, this has been an ongoing problem for me for the last couple of years but has always sorted itself out within a week until about 3 months ago, didn't work for about 4 weeks. I rang Audi to book it in then started working again the next day so cancelled booking. Been working fine for about 3 weeks, had it valeted inside an out then stopped working the next day, that was 4 weeks ago, comes on briefly every so often but hasn't done that recently. Anyway hope you get sorted and would be interested in your outcome. If I find anything out in the meantime I'll let you know.
Mot done,snap on diagnostic picked up low battery errors which I was aware of as the battery was replaced when I purchased the car.
The errors were cleared apart from a communication error which hopefully I will get sorted when I see someone else with vag software.i will keep you posted.
Thanks for that. My friend at work plugged his diagnostic machine in and came up with a code 03157( Function restriction due to communication interruption ) wondered if yours is the same.
Room4TU
15
09-02-2007 08:19 PM
Denisboy
03-13-1999 02:10 AM
