Go Back  AudiWorld Forums > Audi Models > Audi A4 > A4 (B8 Platform) Discussion
Reload this Page >
B8 A4 2009, doesn't start and I'm not sure where to go any more....
A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5-present
Old 04-23-2019, 11:18 PM
Default B8 A4 2009, doesn't start and I'm not sure where to go any more....
Hi guys,
Well it's a story but i'll try to keep it short.
Brought this car at an auction, it didn't start then, i brought it home got all the missing bits, spark plugs, battery ect...
At this current current stage i get three error codes:
08-Auto HVAC -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
Specifically:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
I've googled all three issues and it seems that they should stop the car from starting.
So exactly where i am, i can hear the petrol pump priming when i open the door, the car cranks, don't know how to check if spark plugs are firing or not but they are brand new so they should.
It's an 2009 A4 B8 2.0T Quattro.
Any and all advice or things to try would be appreciated, p.s. those error codes are after i cleared then with the VAGCOM connector.
seinfieldbutsad is offline
Old 04-24-2019, 04:01 AM
You need spark , fuel and air for it to run. I would pull one plug and see if it is wet or dry. Wet is fuel but no spark and dry is spark but no fuel. Go from there . Just because you have new plugs doesn't mean they are getting the signal from the crank position sensor to the coils.
jagtoes is online now
Old 04-24-2019, 10:44 AM
Might also be compression issue. Even if the fuel, air, and spark are there, won't make any magic without compression.
SMac770 is offline
Old 05-11-2019, 02:02 AM
Thanks for the your replies.
I tried starting it again and immediately checking the 1st spark plug, and it is was cold, indicating there was no spark, and dry, indicating there was no fuel.
Would you guys know what the problem could be?
Old 05-11-2019, 05:02 PM
Scrap that, I checked again and the spark plugs smells of fuel.
So it's just the spark I'm not getting.
Would you guys have any ideas?
Old 05-12-2019, 04:52 AM
Normally the plug would be wet with fuel if you have no spark. Now if you have no spark then the CPS , crank position sensor might be the problem.
Old 05-15-2019, 12:49 AM
Wow I was sure I was getting no spark, but I took out the spark plug for the 1st cylinder and grounded it and I'm getting a good, consistent spark.
Looks like it was fuel, but I'm unsure how because I can clearly hear the petrol pump priming when I open the door. Where would I go?
Old 05-18-2019, 05:57 PM
What’s it sound like when you crank it? Can you post a video?
Caelismadison is offline
Scott Free
Off-topic Discussion
17
01-04-2006 03:02 PM
repeater
06-21-2004 10:05 AM
lax01
05-14-2004 06:12 PM
Quick Reply: B8 A4 2009, doesn't start and I'm not sure where to go any more....
