A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
B8: how to fix plenum over flowing with water?
Old 07-26-2018, 03:18 PM
ismailc's Avatar
Default B8: how to fix plenum over flowing with water?
every time it rains heavily, my car battery tends to drain. We have gotten it down to a module underneath the windshield housing/ the one above the drivers' footwell. I forget the name from the top of my head, but the module started with a "J". we found water damage in it and replaced it. we checked the drains right underneath the windshield housing and both drains seemed to check out. But now it happened again. what can I do to fix it?
Old 07-26-2018, 03:19 PM
ismailc's Avatar
I have a 2010 audi a4
Old 07-27-2018, 08:29 AM
Rusty Spokes's Avatar
This forum is for the older A6-c4 cars..prior to 1998.
You have an Audi A4-B8..try your question over here: https://www.audiworld.com/forums/a4-...iscussion-128/
Old 07-27-2018, 10:42 AM
SMac770's Avatar
Received 1,847 Likes on 1,568 Posts
What happened again? Confirmation of water leakage to an electrical component, or drainage of the battery by some event? If the component that was wet before is wet again, break out the hose and find the leak location that's allowing water to go where it should not.
If it rains hard on a long drive, I'll feel a drop on my left foot resting on the dead pedal occasionally. Haven't bothered to try and figure out where it's coming from. Probably somewhere above, but possibly from the top of the door maybe. Your problem might be that the route the water is taking might not be the same once you start removing pieces to try and see what's going on.
Old 07-28-2018, 06:58 PM
ismailc's Avatar
Is this not the A4 B8 discussion? Underneath the "Audi World" logo it says "AudiWorld Forums > Audi Models > Audi A4 > A4 (B8 Platform) Discussion
> B8: how to fix plenum over flowing with water?"
Old 07-28-2018, 07:07 PM
ismailc's Avatar
Both. Yes, the module contained some white water marks on the circuit board and a slightly wet cover and the battery drainage by some event. Yea, I guess it could be possible that the drain pipe itself is impaired. I'll check it out and get back to you.
allroaddave
Audi allroad
11
08-26-2019 07:26 PM
Eddie123
07-31-2015 02:05 PM
stl_tv
12-11-2007 11:49 AM
Audi99.5MA
11-17-2007 11:36 AM
richx
A4 (B7 Platform) Discussion
01-18-2007 08:21 PM
Quick Reply: B8: how to fix plenum over flowing with water?
