Brand new 2012: TPMS messages already?? [Update: It was the tire!]
Is it normal for the TPMS to go off often? It keeps on telling me that my front left tire needs attention. I look at it, and it looks fine, so I reset TPMS. Then a few days later, it goes off again.
Could this be due to the untold heat here in the North East? Or is this a hypersensitive TPMS gauge? Meh - brand new car already has issues?? |
Have you verified that the tire's pressure is correct and it's not leaking?
Have you actually checked it with a air pressure gauge? I would suggest that before passing go or trying to collect $200.
If it's where it supposed to be, then yes it could be a faulty sensor on that end of the car. FYI, TPMS is run from the same system that runs ABS/ESP on our cars. |
Originally Posted by UmIsThisThingOn
(Post 24172342)
Hav
The TPMS has never gone off for me, even in -25F weather. I wonder if one of those wonderful P6s already gave up the ghost.
Jon, the best thing you can do is to verify the correct pressure in all 4 tires using your most accurate tire gage.
I would check and set the pressures on all the tires and do a reset. If that doesn't do it then let the dealer deal with it.
Hey guys,
I am feeling a bit moronic, but thanks to the collective (and individual) wisdom here, you actually opened my mind to the possibility that the tire could actually be at fault! So, I found my tire pressure gauge and, lo and behold, my front-left tire is at 23.5 and my front-right tire is at 35.5! So, it does seem as though the tire is at fault after all. I'll be honest -- my pre-disposition toward Audi quality immediately led me to the electronics being at issue. I also couldn't fathom a brand new tire already dying (I did eyeball it and it seemed fine). Combine these two faulty presumptions, and you get a faulty assessment. I stand corrected. Now I need to figure out how to get this tire repaired. The dealer will cover this, right? I don't have to go directly to Pirelli, do I? |
Now you know at least there is no problem with the TPMS :) It always helps to get suggestions from others.
But how new is your car? Could it be that it was delivered from the dealership with a fairly low pressure to begin with? Inflate it back to the proper pressure and just wait to see what happens. If it deflates again, then you know there is a problem, either with the tire or the rim. Btwy, have you checked whether there is a nail or some other sharp object embedded in your tire? You want to make sure you don't go to the dealer with a non-problem, otherwise they might brand you "the boy who cried wolf" and they might not take seriously your future complaints (hopefully there won't be any). |
Hey, that's more good advice. However, I've already emailed my sales guy to let him know what's up (twice - once thinking that TPMS is broken, and then to correct myself that it's the tire).
Because the car is only 5 days old, I'm presuming that the TPMS alarm going off twice is 5 days means that the tire really is at issue. I really shouldn't have to inflate such brand new tires, correct? I suppose I'll check with nails tomorrow morning, but that seems soooo unlikely... but I'll check! Thanks!
Originally Posted by av_audi
(Post 24172384)
