cabin air filter
cabin air filter
such a simple DIY but I can't get the filter back in.
Watched the videos on YouTube.
Notch is upper right - correct?
Is there a trick? Seems to get blocked for the last inch or so.
Same install Issue
I am having the same issue. Watched all the videos which make it seem way too easy. I have wiggled it for an hour plus in all sorts of orientations and it just won't go in the last inch. It is like there is a valve flap or something blocking it from going in. Anyone have a suggestion???
If you made sure they are the same size, then you shouldn't have a problem. I did mine without issue, there wasn't really any trick to it. Try putting the other one in again and make sure your orientation is correct. Try to drop it out a few inches and jam it in with one quick motion.
Are you sure you have the correct replacement? The are 2 similarly shaped, but different sized cabin filters.
1) for A6 https://catalog.mann-filter.com/EU/e...ter/CUK%202641
2) for A4 https://catalog.mann-filter.com/EU/e...ter/CUK%202450
S4Ca$hwhore
08-14-2006 08:14 PM
BSK
02-01-2006 02:21 PM
dieRICEdie
05-02-2003 12:29 PM
