Check engine light
Check engine light
Solid light came on, had a pressure sensor replaced and the light came on again the same day. Everything else seems fine, no noises, no rough idling, no stalls, or strange odor from the exhaust
Get your local VCDS person to scan the car. Without that, you've got nothing.
Check Engine Light
2013 A4 Quattro with 67,750 miles on it
Solid light came on, everything else seems fine, no noises, no rough idling, no stalls, or strange odor from the exhaust.
code P0299, had the boost sensor replaced the other day to the tune of 265 buck and the light came on 12 hours later.
What is the new code causing the CEL?
I don't hear any noise out of the ordinary or have problems accelerating. The oil has been changed religiously as well as oil filters, I only use mid grade or premium gas, the car only has 65,750 miles on it.
P0299 just means something between the air going into the intake and the air coming out of the tailpipe is not functioning as expected. Yeah, that's not much help, just as helpful as P0299 is.
The turbo or some component of the turbo is frequently an involved part, but it could be elsewhere in the engine as well.
Was the reason for replacing the boost pressure sensor (this is the one in the pipe from the intercooler to the throttle body?) also a P0299?
