Child-proof lock: System Fault!
Good afternoon,
This morning my 2013 A4's MIL turned on and it showed "Child-proof lock: System Fault!" in the driver's display. After about 1/2 minute the car shut off as if gasoline supply was cut off. I checked the fuel cap and started the car again and almost immediately it shut off. I had both door's child locks engaged and decided to temporarily set them back to normal (manual system with the key). No change in behavior after starting the car. Same message and shut off again. I am suspecting a fuel pump thing or something really odd. Anyone ever seen this? Is there a safety system that would cut fuel supply when the child proof locks malfunction? Any idea would be appreciated before I head to a dealer and get stuck on the highway...
Thanks!
Thanks!
First thing you do is pull codes and then see what the car is telling you. Maybe even clear codes and see what comes back in case it seems a random event.
Audi's dash lights are particularly uninformative when you are needing to formulate an action plan.
Shiny Red Beast
04-03-2007 08:39 AM
That's it... enough of all this his fault, my fault, your fault BS... all everyone needs is a little
BukkakeRocky
NY / NJ / CT Discussion
55
06-25-2004 09:34 AM
