Chirp gone, central locking always cycles
A few weeks ago the alarm stopped chirping on lock. One door wasn’t locking so I replaced the actuator and the door now locks, but the chirp is still not back. All doors lock but the gas cap door does not lock. When I stop and drive above 10mph, I can hear the central locking switch trigger locking all doors, but it will continually do this if I stop and take off again. It doesn’t think it’s locked, which also points to the chirp not chirping. I replaced the fuel door switch to no avail. Any thoughts?
Any luck with this? Mine will lock with the fob, and with the button on the door. I think one of my rear door buttons is broken now.
All kinds of stuff on these fail, door locks, buttons, speakers, the rear deck sub, door latch cables, shock bellows damper, its a constant string of parts.
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000007912630
Coding: 010C03204000210001
Shop #: WSC 06335 000 00000
VCID: 3FDBBE07377D2CEF48D-806A
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 164
Mileage: 183542 km
Time Indication: 0
Date: 2018.08.20
Time: 15:38:13
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Part No SW: 8K0 907 064 CS HW: 8K0 907 064 CS
Component: BCM2 2.0 H07 0437
Revision: 00002001 Serial number: 0414121207
Coding: 0126023A207A001400B0020000000000
Shop #: WSC 00612 002 1048576
VCID: 035372F71B15880F6C5-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS127 H06 0037
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J394 PS222 H06 0037
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 164
Mileage: 183542 km
Time Indication: 0
Date: 2018.08.20
Time: 15:38:52
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 164
Mileage: 183542 km
Time Indication: 0
Date: 2018.08.20
Time: 16:01:54
The fuel door codes are just your solenoid going out. I recently replaced mine because it got to the point that occasionally I was having to lock/unlock several cycles to get the solenoid to release. But the solenoid is a dumb device and the status of it is not part of the locking system. It just toggles the power line when you lock or unlock the driver door. It is interesting though that yours does not say " - Intermittent" as my codes did. My fault status was 00101001, but who knows what those bits means.
Your first post said you already replaced the fuel door solenoid? 8K0862153H? Did you voltage test the plug to the solenoid to make sure 12v was present? (I'm not sure if 12v present is locked or unlocked; or maybe it only needs to pulse some 12v to toggle the state; not sure how it actually works inside). Something must be bad with the wiring to the solenoid if you replaced it and it's still giving errors.
I had to replace a rear door latch, I ordered and replaced the Audi part# 8K0839015A
it locks and unlocks with the fob now, but no chirp anymore, but I can live without it over a visit to the stealer and their $198 diag fee.
Sounds like a the door lock actuator to me. Happens when you get some moisture in the door and weather changes and make it short out. I think you can find it for around $200. DIY is straightforward but a PITA.
