CODES for Check Engine Light
The check engine light on my car is still turned on even after replacement of the coolant bypass valve and switch, as per the codes. Does anyone have a clue what else needs fixing?
Thanks in advance for your advice
CODES:
1) P2681 - Engine Coolant Bypass Valve Control Circuit/open
2) P0116 - Engine Coolant Temperature Sensor 1 Circuit Range/Performance
3) P2181 - Cooling System Performance
CODES:
Do you think the other 2 temperature sensors/switch require replacing?
Or possibly the Passenger (backseat) air-con coolant bypass valve needs replacing?
Usually code "stack" meaning that the 1st code is the problem and it triggers the follow on codes. What was your 1st code and did you check that component for it's electrical value prior to replacing it.
First code is P2681 coolant bypass valve that was replaced by a mechanic, I assume they followed the protocol and tested the electrical value of the parts before installing it.
That being said, only 1 of the 3 switches was replaced
I'm assuming the mechanic followed standard protocol and tested the electrical value before putting in the new part.
Only 1 of 3 switches was replace though, do you think the other 2 switches may be faulty?
This is the first code:
I would not ASSUME anything. Now days I find that "mechanics" just replace parts instead of diagnosing the problem. Someone should be able to check the circuit with a meter to verify if the other switches are working correctly. By the way did you ask him for the bad parts.
I did get the original bypass valve back, the entire part is sealed so unsure if the original part is actually faulty
I have the same error code on my Audi A4 1.8 2013, could anyone tell me where i can find the coolant bypass valve, please.
biIIy
A4 (B8 Platform) Discussion
03-15-2018 12:19 PM
protoaudi
A4 (B7 Platform) Discussion
08-17-2010 12:48 PM
sidespar
08-13-2007 07:17 PM
