A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
No fan no compressor
Old 08-06-2018, 08:44 AM
thjohnson58's Avatar
Default No fan no compressor
I have a 2014 A4 29K miles. Left the resturant no ac. Compressor not engaging. Ac light on . Interior fan working. Radiator fans not on with ac switch. Drove around reached operating temperature and no fans. Did not drive that far but temp gauge read where it is supposed to. Radiator Fan fuses good. AC fuses on for passenger and driver side fuse box for what appears to be ac circuitsgood.
Old 08-07-2018, 04:23 AM
Can someone let me know where to look on my year 2014. I have read the other post but those are older models. I understand the harness changes from year to year. I am a competent electronics technician.
Old 08-07-2018, 11:16 AM
Static charge is 100 psi. Check every possible fuse. No compressor no fans.
Old 08-08-2018, 07:02 PM
audi bug's Avatar
Where was the radiator fan fuse you checked?
Only fan fuse I know is the either 40 or 60 A fuse on terminal block 30 at the cowl.
Old 08-09-2018, 02:37 AM
Thanks for your help. I really appreciate it. There is also two other fuses that are tagged air conditioner that I checked also. I cannot find a schematic on the car. I went to audi wier but those diagrams are pretty much useless. I bought a diag tool that should be here today. Perhaps an error code will show me the way. I am beginning to believe its the fan controller. I just can't confirm from any of the forums that it too turns on the compressor clutch. Hard to believe I am having problems on a car with less than 30k miles and a 2014 B8.5. I believe that the controller handles the current and there are no other relays on this model. Although that could be incorrect.
I should know more later today. I will post any codes.
Once again thank you for your response
Old 08-09-2018, 09:36 AM
fault codes 00256 and 00457 AC pressure switch. First what pressure should I see static?
Do I have to drain the system to change the switch ( stupid question but I have my fingers crossed)
Old 08-09-2018, 07:21 PM
Pculvert's Avatar
Most likely fan module, if fans don’t come on, compressor won’t engage, do the fans ever come on?
Old 08-10-2018, 02:22 AM
so the latest. I bought carista and the error codes are 00256 and 00457 . The first is the low pressure warning. The second is a communication error. I read on another forum the 2013 and 2014 had a run of bad ( not lasting very long) sensors. It makes sense as this part would wear with age and not use. My car only has 29k. For 40 bucks I am going there.
No my fans do not come on or at least when I am in a position to hear them. BUT the car never goes past the center line on the temp gauge. Just like it always acted previous to this issue. Perhaps they do come on low running down the road and I cant hear them. But at any rate in Fl and it is hot right now the car is not overheating.
This car did not have a scratch when I bought it. 12k miles and 3 years old.No one had sat in the back seat yet. But one of the plastic inserts in the panel that covers the radiator-condensor was missing?
Old 08-10-2018, 05:15 AM
My car is working perfectly. $40 dollars and the cost of carista. The pressure sensor was bad.
dkarten
08-11-2010 05:20 AM
kkii9
06-17-2008 09:21 AM
S4 TTime
07-16-2002 06:33 PM
Asten Johnson
Misc. Models Discussion
03-28-2001 03:39 PM
Quick Reply: No fan no compressor
