Drive select dynamic steering - is power assist level variable (on top of ratio)?
Audiworld Member
I am debating whether to add ADS to my order and have a question about the dynamic steering.
I know the dynamic steering adjusts the steering ratio based on speed and ADS setting (so steering is more indirect at higher speeds and with ADS in dynamic mode). But is the level of Servotronic power assist varied too? Does it make the steering significantly heavier at low speeds, or does it just make the steering ratio more direct (e.g. fewer turns of the steering wheel to turn the wheels)?
To me the steering would be the main reason to get ADS (as I can live with the S-line suspension), but $3000 is a lot so the benefits would have to be amazing for it to be worth it.
(I have been trying to test drive an ADS car, but dealers don't seem to order them for stock.)
I believe all the B8's have variable assist steering regardless of other options or trim (as you note, not to be confused with the variable ratio of ADS).
Audiworld Member
Maybe I should clarify my question - I am particularly trying to figure out if changing the ADS mode affects the level of steering assist (basically, if Dynamic mode makes the Servotronic steering less assisted at low speeds).
Coming from a BMW I find the light steering at low speeds disconcerting, so I am curious if ADS changes how Servotronic boosts low-speed steering assist.
Changing Dynamic Steering setting changes Servotronic as well
The difference between in steering effort in the three modes is dramatic and is the first thing you would notice when switching ADS settings.
As the previous poster noted you have get Nav in 09 to control the Individual mode. I don't find Dynamic mode suitable for everyday driving - auto transmission sticks to a very aggressive program that is quite annoying if you are cruising on the highway. Personally, I keep steering in Dynamic mode, drivetrain in Auto and suspension in either Dynamic or Comfort depending on who else is with me in the car or on the quality of the road.
