Drivers door wont unlock
My audi drivers door has stopped unlocking with the remote,all other doors are ok.
If i use the key,i can unlock the door no problem,it locks fine with the remote,but when i return to unlock it,it doesnt work,,,,,,,,i get this fault code if i erase it,it comes back instantly.
1 fault found:
02115-locking unit for central locking
008-implausible signal-intermittent
freeze frame
fault status 00101000
fault priority 3
fault frequecy 6
reset counter 139
What exactly do i need to replace?
1 fault found:
freeze frame
fault priority 3
fault frequecy 6
reset counter 139
1 fault found:
freeze frame
fault priority 3
fault frequecy 6
reset counter 139
1 fault found:
freeze frame
fault priority 3
fault frequecy 6
reset counter 139
you can do what i did first,remove door card and put blenty of lube....i.e. wd40 and grease the latch up,there is a cable aswell that tends to stick,clean it ,grease it,lube it......it should fix the problem....it did mine,if not you need this..................https://www.ebay.co.uk/itm/FOR-AUDI-...tXlj:rk:6:pf:0
ALWAYS TRY DEALERS FIRST,SOMETIMES SIMILAR PRICE.............i would not bother with a used one,if you do get exact part number,otherwise once fitted and locked,you wont be able to unlock it again.
Cmmartin23
26
08-23-2016 04:44 PM
