Dynamic Steering Light + System Fault error after rear backup cam install
Hi all, my first post here. I just got pre-owned 2014 Audi A4 a few weeks ago.
I know little about cars, so I had a car stereo installation place install my rear backup camera from carsgadget. The camera itself and everything works fine. On the drive back I noticed my steering wheel was stiff and saw the steering wheel light + system fault error show up.
Questions:
1) Do you think this was caused by a poor install job/disconnected wires? (I remember the installer talking about how I had no more open fuse slots, so maybe he did something wrong in this area?)
2) The car is still under warranty, should I try to get it serviced or remove the rear backup camera first?
3) I googled around and some people were able to fix this steering problem with a "basic settings" programming for their dynamic steering. Knowing my details, is this something that sounds like it would fix my problem?
4) Is there anything I can check easily myself?
Thanks in advance!
Questions:
Thanks in advance!
Questions:
Thanks in advance!
Questions:
Thanks in advance!
How did you fix this? I installed a backup camera today, and I am having the exact same problem. Carista also gave me a list of 7 fault codes, and they wouldn't go away upon reset.
CAN network gateway
Part #: 8R0907468L
Coding: 80C303FF00 (hex)
Component: GW-BEM 5CAN
[No fault codes]
Ignition authorization
Part #: 8K0907064HM
Coding: 0D814040000000000000 (hex)
Component: BCM2 2.0
[No fault codes]
Central electronics
Part #: 8K0907063DF
Coding: 26000091863CAFC00000480300003D0D0F1C53082209022100 0008004000020100000000000000 (hex)
Component: BCM1 1.0
[No fault codes]
Body/convenience system
Part #: 8K0907064HM
Coding: 0106063A00FA400580B0013200000000 (hex)
Component: BCM2 2.0
[No fault codes]
Driver's door
Part #: 8T0959793P
Coding: 011C13204E00410001 (hex)
Component: TSG FA
[No fault codes]
Front passenger's door
Part #: 8T0959792P
Component: TSG BF
[No fault codes]
Rear left door
Part #: 8T0959795Q
Coding: 010C13204000210001 (hex)
Component: TSG HL
[No fault codes]
Rear right door
Part #: 8T0959795Q
Component: TSG HR
[No fault codes]
Driver's seat
Part #: 8K0959760D
Coding: 00581B00000000000000 (hex)
Component: MEM-FS
[No fault codes]
Heater & air conditioning
Part #: 8K1820043T
Coding: 6400208000 (hex)
Component: KLIMA 3 ZONEN
[No fault codes]
Steering wheel
Part #: 8K0953568Q
Coding: 000016 (hex)
Component: Lenks.Modul
[No fault codes]
Instrument cluster
Part #: 8K0920951E
Coding: 8B9709000301D705020000 (hex)
Component: KOMBIINSTR.
[No fault codes]
Parking brake
Part #: 8K0907801M
Coding: [none]
Component: EPB-4
[No fault codes]
ABS
Part #: [none]
Coding: 081D1801 (hex)
Component: ESP8 front
[Failed to check fault codes]
Steering angle
[failed to connect]
Airbags
Part #: 8K0959655P
Coding: 303844354730303030304A55304C384B3053 (hex)
Component: AirbagVW-AU10
[No fault codes]
Engine
Part #: 8K5907115M
Coding: 4A030013242400062000 (hex)
Component: 2.0l R4/4V TF
[No fault codes]
Transmission
Part #: 8K9927155
Coding: 000001 (hex)
Component: 0AW 20TAVSUSA
Fault codes:
02223 Manufacturer-specific code
02300 Manufacturer-specific code
02309 Manufacturer-specific code
05676 Manufacturer-specific code
05677 Manufacturer-specific code
Media player
Part #: 8T0035785A
Coding: 020302 (hex)
Component: SG ext.Player
[No fault codes]
Radio
Part #: 8R1035186Q
Coding: 040200020101850043D9070800 (hex)
Component: Con3 Sirius
Fault codes:
02259 Information display and control head, front (J685)
Telephone
Part #: 8T0862336F
Coding: 10370 (decimal)
Component: FSE_256x BT
[No fault codes]
Sound system
Part #: 8R1035223A
Coding: 0203010102 (hex)
Component: DSP STD
[No fault codes]
Power steering
Part #: 8K0909144F
Coding: 100000000001 (hex)
Component: RCEPS
Fault codes:
5258753 Manufacturer-specific code
Obtained with Carista 343099 for iOS.
CAN network gateway
Part #: 8R0907468L
[No fault codes]
Part #: 8K0907064HM
Component: BCM2 2.0
[No fault codes]
Central electronics
Part #: 8K0907063DF
Component: BCM1 1.0
[No fault codes]
Part #: 8K0907064HM
Component: BCM2 2.0
[No fault codes]
Driver's door
Part #: 8T0959793P
Component: TSG FA
[No fault codes]
Part #: 8T0959792P
Component: TSG BF
[No fault codes]
Rear left door
Part #: 8T0959795Q
Component: TSG HL
[No fault codes]
Rear right door
Part #: 8T0959795Q
Component: TSG HR
[No fault codes]
Driver's seat
Part #: 8K0959760D
Component: MEM-FS
[No fault codes]
Part #: 8K1820043T
[No fault codes]
Steering wheel
Part #: 8K0953568Q
[No fault codes]
Instrument cluster
Part #: 8K0920951E
[No fault codes]
Parking brake
Part #: 8K0907801M
Coding: [none]
Component: EPB-4
[No fault codes]
ABS
Part #: [none]
Steering angle
[failed to connect]
Airbags
Part #: 8K0959655P
[No fault codes]
Engine
Part #: 8K5907115M
[No fault codes]
Transmission
Part #: 8K9927155
Fault codes:
Media player
Part #: 8T0035785A
[No fault codes]
Radio
Part #: 8R1035186Q
Fault codes:
Telephone
Part #: 8T0862336F
[No fault codes]
Sound system
Part #: 8R1035223A
Component: DSP STD
[No fault codes]
Power steering
Part #: 8K0909144F
Component: RCEPS
Fault codes:
kerem75030
A4 (B8 Platform) Discussion
02-03-2019 04:52 AM
tennisjock
TT (Mk2) Discussion
12-30-2008 06:19 PM
