:: ECS Tuning :: B8 A4/S4 Rocker Panel Side Blades!!
Audiworld Basic Sponsor
Give your B8 A4/S4 a unique look to help it cut through crowds, and help cut down on road damage, too.
These Genuine Audi side blades arrive in a primed finish with all required hardware, ready to be paint matched and installed on your vehicle.
Note; these are a direct-fit install on S-line cars. However, non S-line vehicles will require slight modification for installation.
These side blades are the quickest way to sharpen your B8 Audi A4 or S4.
High grade side blades for your Audi.
Click HERE to order or for more information
*This is a replacement kit for S-Line models. Non S-Line models will require custom modification for install*
Fits:
AUDI B8 A4/S4 (2009+)
Let me know if you have any questions.
Jason
Fits:
Jason
Jason,
Do you know what kind of modification needs to be done for these to fit onto non s-line models? I can't imagine it's that different between models, seems like the side blades themselves are the only visual difference and should be a simple "add on".
Thanks!
Thanks!
It depends on how you want to install them. If you want to mount them with screws you'll need to drill in to the rocker panel.
Most people mount them with 3M double sided tape. This requires no drilling and usually if installed with care can provide just as well of a hold as screwing them on.
I hope this helps!
Jason
I hope this helps!
Jason
Great, thanks! I wasn't sure if the "custom modification" for non s-line meant actually modifying the plastic part or getting the clips mounted.
I work at 3M, was hoping it would as simple as just using some double sided tape.
Yeah, it only really applies if you want to mount the clips using screws.
You would basically need to drill into the rocker panel, which if you plan to make them permanent wouldn't be so bad, but many would rather not drill screws into their vehicles.
Jason
Jason
ECS Tuning-Audi
S4 (B8 Platform) Discussion
08-05-2013 06:46 AM
ECS Tuning-Audi
Vendor Showroom
08-02-2013 01:07 PM
takai
10-21-2002 09:12 AM
:::EuroRacerGT:::
05-01-2002 10:02 AM
