Engine replaced under warranty
On Tuesday 8 October my wife calls me on her way home for lunch and said that her 2012 A4 with 25000 miles is running very rough and has a blinking check engine light. She pulled over and shut it off. I called Audi and they sent out the roadside assistance tow truck. The nearest dealership was 150 miles away so that's where the took it. They diagnosis was a leaking fuel injector in the #3 cylinder. They replaced the injector and spark plug because it was fouled and cleaned the carbon deposits. When the re started the car it still had a severe miss and the blinking check engine light. They performed a compression check and found that the #3 had 0 psi compression. All other cylinders had 140 psi. When they tore the engine down they found gasoline in the oil and a broken ring on the #3 piston causing a scarred cylinder wall. They replaced the engine with a brand new unit. Should I be concerned about future resale or trade in values since the engine has been replaced? Also, does this happen very often? We have enjoyed the car very much and it was a little disappointing that this happened.
While it can happen, it's a very rare occurrence for an engine to be replaced. It won't hurt your resale value at all and in fact could increase it with a private sale as the engine will be 25K miles newer. Be sure to save all your service documentation.
As to the new engine warranty, I'm guessing it will be equal to the remainder of the factory 4 years/48K miles as left on the rest of the car.
Hi,
Within the last 6 weeks, I've had all 4 injectors replaced (on two separate occasions). The symptoms were the same as yours, but luckily I didn't need the engine to be replaced.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
carl viking
36
04-27-2020 01:17 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
