EPC and CEL + power loss and shake.
#41
Probably injectors! They tend to act up when cold/idle more so than under load. I have replaced FSI injectors that idled badly but "drove" just fine. Yeah for modern technology!!!!
TFSI
Totally
Fecken
Sh**ty
Injection system!!
Just like DSG
Das
Sh**ty
Gearbox!!
TFSI
Totally
Fecken
Sh**ty
Injection system!!
Just like DSG
Das
Sh**ty
Gearbox!!
#42
I had TSB 2024812/4 performed today, which includes the following:
Software Update
Replace Pressure Regulating Valve
Replace Front Crank Seal
The dealer believes that this will fix the rough start issue and excessive oil consumption. At least the dealer performed the TSB without a fight and did not give me a "could not replicate" or "all A4s are like that" type of excuse.
Software Update
#43
Twice in the past week, my car has started roughly for around two seconds, accompanied by the EPC light and fluttering tachometer. After two seconds of running roughly, the car started correctly and ran normally. Does this sound like the fuel injector issue? I will be calling my dealer tomorrow morning to make an appointment.
#44
The TSB seems to have fixed both the rough start issue and the excessive oil consumption. The car has not started roughly since I had the TSB performed over a month ago and oil consumption has decreased from 3/4 quart in 800 miles to still reading full on the MMI after 450 miles. Hopefully, your dealership is receptive to performing the TSB.
#45
Time to revive an old thread. While driving this afternoon, I accelerated from around 30mph and my car started shaking violently, the check engine light started flashing, and almost all power was lost. I immediately pulled into a parking lot and restarted the car, but the result was no better: The car shook violently even when idle and could not driven safely at any speed. The car is now sitting at the repair shop and will hopefully be diagnosed tomorrow morning. Based on my research, it appears that the following could be the culprit, in order of likelihood: fuel injector(s); fuel pump; POS plastic intake manifold.
Anyone have a similar experience?
#47
Cat Herder
#49
I have had this issue happen to me while driving on the highway today. My car started shaking and losing power, EPC light came on then the Check Engine Light followed. Thankfully, the highway was busy and I was able to safely pull over without causing any traffic.
I was able to load some codes and they were relating to multiple cylinder misfires (1 , 3 , 4 , and 6 I think). I am out of warranty and was wondering if this is a problem that persists with the B8 S4? Worth it to sell? (Currently have 130000KM on my 2010 S4)
#50
