Erratic Idle 2.0 TDi B8 2010
HI all, my first post. I ve read loads on this forum and online about erratic idle on Audi's ... after tons of YouTube etc i made the plunge and changed MAF ...still the same ... took off EGR and cleaned the hell out of it ( wasn't too dirty tbh) ...that made a difference when driving i must admit but not on idle. I then heard a slight clicking noise with engine cover off and ticking over ...coming from the front right of the engine .. i think it is the High pressure pump? What is the sensor on that? When i rev the car it sounds like there is a little bit of metal floating about in there..when i followed the fuel pipes to near the bulk head and felt the pipe and on tickover it was almost like a throbbing feeling...is this correct? Any help would be gratefully appreciated...its driving me nuts !!
BUMP my own post .
This was my problem and was fixed with changing the fuel regulator valve on the fuel rail.
Drove me crazy but anyone having same problem try this .
BUMP my own post .https://www.youtube.com/watch?v=fT9i3aZ0BC4 This was my problem and was fixed with changing the fuel regulator valve on the fuel rail.
How to
Hi all,
Thanks for the information below ! Likely to save a small fortune in diagnostics costs !
Is this simply a matter of removing the old and replacing with new ? Couldn't find any guides or how to (even on Haynes).
Dont have VCDS so cant bleed the fuel system if it comes to it and want to make sure this isnt part of the process !
Thanks
Scott
Thanks
Scott
reinstone79
10-24-2010 07:23 PM
kens4
06-06-2004 06:50 AM
