Fault codes
That's just the list of modules with DTCs present. You need to copy/paste the entire log. Wrap it with a code block, put [..code] before and [../code] after (but remove the .., I just put that there so it wouldn't process the tags).
Thank you
Kind regards,
Tendai
You just type code in square brackets, type (or paste) your log, type /code in square brackets.
Sten M
05-19-2018 11:46 AM
Avant Eric
VAG-COM Discussion
04-07-2005 03:53 AM
That's it... enough of all this his fault, my fault, your fault BS... all everyone needs is a little
BukkakeRocky
NY / NJ / CT Discussion
55
06-25-2004 09:34 AM
mm
9
04-08-2002 03:57 PM
changs4
10
11-17-2001 07:39 PM
