Help needed, bunch of error codes
I have Audi A4 B8 2008 model with 1.8 engine and CVT with following codes:
01 Engine:
Trouble codes:
U111300 - Function limitation due to received malfunction value
static
static
P169800 - Steering Column Electronics Read out DTC
static
02 Transmission
Trouble codes:
P073000 - Gear Incorrect Ratio0
3 Brakes
Trouble codes:
00778 - Steering angle sensor Please read DTC
static
09 Central Electrics
Trouble codes:
00466 - Steering column electronics control module Please read DTC
16 Steering Column
Trouble codes:
00778 - Steering angle sensor Faulty
static
00778 - Steering angle sensor Implausible signal
static
62 Rear left door
Trouble codes:
02115 - Lock unit for central locking Implausible signal
static
Feels like I won a jackpot
... Please share where would you start...PS. At the moment only ESP light on. When driving the car for more than 10 mins it shift gears randomly (CVT?) and some times doesn't react to the throttle at all or would accelerate randomly.
Any help is highly appreciated. Thank you
