New to me 09
New to me 09
Hey everyone , this is my first non gm or Ford vehicle. I picked it up cheap from a friend who was basically driving it into the ground.
It has so many issues. The most obvious is the exhaust falling off of it,cylinder 1 misfire, mmi dead , blowing cold air.... the list goes on
Engine electronics
P030100 Cylinder 1 misfire detected passive/abiogenisis
P130a00 Hide cylinder passive/abiogenisis Transmission
00446 Function limitation due to under voltage. No fault type identified
00532 Supply voltage b+ No fault type identified 01765 Engine control module Regulation difference Value of resistance too great
00493 Esp-sensor unit
g419 Short circuit to another valve
Access and permission
00956 Key 2 Defective
00446 Function limitation due to under voltage No fault type
02812 Supply voltage terminal 30 for electronic steering column lock
01330 Central control module for central convenience
j393 Instrument cluster
00471 Control module for electronic regulated dampers
j250 Central control module
02616 Fuel cap unlocked
00166 Access/start Authorization switch e41 5 Short circuit to another valve Radio Can't connect Sound system
00871 Bass speaker front right r23
01304 Radio
There are also dozens of low voltage codes
it pasted funny hopefully i separated them correctly.
the battery has been dead for a while. Does a simple battery swap along with a new plug and coil fix most of the issues or did the previous owner Drive it tobits grave?
thanks for any help/suggestions
Chad
Engine electronics
01304 Radio
Chad
If the battery was just replaced, clear the codes and see what comes up after a drive. Modern cars can do weird things when the battery goes dead. These cars are notorious for oil burning problems due to faulty pistons/rings, so don't be surprised if cyl. 1's plug is fouled with oil.
I haven't done anything with the since I made the post other than some reading. I since learned about the oil consumption issues . I thought that was most the 4 cylinder cars? This one is the 3.2 . The battery is basically no good. I'm having a difficult time if convincing myself to put any money into it.
thanks for the reply
Chad
Chad
powderlvr
01-17-2018 12:43 PM
Garth
09-08-2008 08:12 PM
