New (to me) A4 - question on hands-free
Just got a 2009 A4 Prestige, Bluetooth pairs fine with my iPhone 4 and calls coming in show up on the MMI display. I can answer/make calls but when i hit the push-to-talk button display says Button Inactive. It there a separate hands-free option I don't have? I don't have the MMI manual either, is it not easily available at audi's site? Seems odd.
incoming calls show up on the MMI and mute the stereo. i can answer with the steering wheel control or with my phone but the other person can't hear me. i can make outgoing calls by selecting the name from the MMI or steering wheel control but no sound. i'm referring to the push-to-talk button on the steering wheel
Push that button when not on the phone, and you should hear a beep. You can then say things like "Call mom" or if you have the nav, "Enter City", etc...
Also a good way to test out the microphone, btw -- if you can execute voice commands successfully, then the microphone is physically working and it's an issue with the bluetooth module. My guess is, voice commands aren't going to work either.
ok that makes a lot of sense. could it be the mic is turned off? i didn't see anywhere in the MMI a way to turn the mic on and off. I do recall once seeing what looked like a 'mute' icon on the bottom of the MMI display (speaker with a line through it). or could that icon mean the audo is just malfunctioning. also don't have the MMI manual
The "mute" icon at the bottom appears when you turn the sound all the way down (i.e., when the volume in the car is totally muted). You should see it appear if you press the volume **** too.
Do you have any sort of warranty? Was it purchased from a dealer or private party?
I am not aware of any way to turn the mic off. Unfortunately, it kinda sounds like you may have a physical connection problem somewhere.
The Mute function (of the sound system) is automatic when making/receiving a call.
There seems to be many versions of "Speach Dialoge"/"Voice Command"/"Telephone Voice Tags". I read that some cars have the possibility to record voice tags, but have the function disabled.
Try to get the hands-free function working first.
I don't think this is the problem, but "Microphone Off" setting is available under "Options", while a call is active. It should show a message on the display.
The poster is suggesting that he is never heard by the receiving end, from the get-go...
That is the reason I wrote "I don't think this is the problem, but "Microphone Off" setting is available under "Options", while a call is active."
are you hitting the button with the picture of the face or hitting the scroll wheel button to pick up?
to pick up a call and to select a number from the directory, i press the scroll wheel not the "push-to-talk" button.
