Power steering very heavy and stiff
2 immediate causes come to mind.
- Stiff U joint in shaft - clean and lube while working back and forth with wheels off ground
- Bad fluid - flush fluid using a turkey baster. Remove and replace from reservoir as much as you can. Do this every day for a week and you should feel improvement
Both of these issue can occur rather suddenly. And the old fluid will likely look fine.
larsenracing
18
03-27-2018 10:42 AM
setUout
06-09-2004 09:16 AM
