RE: Coolant fluid!!
#11
You're in Poland, so note your lowest expected temp and make the mix per the chart on the container. 50/50 is good to -37C. 60% coolant / 40% water is good to -52C. Use distilled water.
#12
I can only find the below concentrated coolant here! And in Warsaw the Lowest expected temp is around -25C, so shall I mix 50/50 ratio?
Note - Woda is water in Polish.
Found the below in my Owner's manual,
#13
Sasi, you'll be fine with 50/50. Far more protection than few of us will ever require. Isn't the car kept in an underground car park?
#14
Planning to top up with concentrate Anti-freeze coolant(500ml) + Demineralised water(1L) as temperature will not go below -25C in Warsaw and I have an underground garage parking, so hope this mixture will work.
Please give me a heads up , if I am wrong.
#16
Get some coolant in there and monitor the level over the next few weeks. I don't think there's anything else you can do now. You need to verify whether you are losing coolant.
#17
Nothing else you can do apart from monitor the lever and see if it continues to drop.
#19
#20
Yeah, that needs to be looked at, Sasi. That looks significant. Good detective work finding it. Maybe it's just a hose that needs to be replaced or a bad clamp.
