- Audi A4 B8 How to Replace Spark Plugs and Ignition Coils<br>Step by step instructions for do-it-yourself repairs.
Replace spark plugs when?
When I view the recommended plug changing intervals for the 2009 A4, Audi now says the following:
– replace at 35,000 miles or 3 years, whichever occurs first. Then, every 40,000 miles or 3 years, whichever occurs first.
– replace at 55,000 miles or 6 years, whichever occurs first.
Then, every 60,000 miles or 6 years, whichever occurs first.
– replace at 75,000 miles
A5 2.0L TFSI, TTS, A3 3.2L,
TT 3.2L and A8 6.0L only
l 55K only: except A3 3.2L,
TT 3.2L, A4 2.0L TFSI,
A5 2.0L TFSI, TTS and A8 6.0L
75K only: A3 3.2L, TT 3.2L,
A4 2.0L TFSI, A5 2.0L TFSI,
TTS and A8 6.0L only
Can anyone else confirm which scheduled maintenance or mileage (35k, 55k, etc.) they changed their spark plugs for the first time?
Has anyone had their spark plug replacement paid for while under Audi Care?
The dealer has an over promoted lot porter who declared that the 75,000 mi service was plug time. The chart is confusing because it is on an x-y grid. For the A4 2.0T TFSI 35K mi for the first change, then every 40K mi.
At 70,000 I had a check engine light and missing on accelration. I took it to the dealer and they said it needed coil packs. Skeptical, I took the car home and tested the coil packs. They were all good, except on one the harness side connector had the locking clip broken off, and the secondary side of all the coil packs were covered in engine sealant. The dealer had the head off at 45K to change the pistons, and lathered up a little too heavily with the sealant.
Fixing the connector fixed the check engine light, and changing the plugs stopped the missing. I used a little solvent to remove all the sealant from the coil packs, and they work fine.
The correct Bosch plugs are expensive at $15 ea from auto zone and the rebate company cheats you out of the $2 per plug rebate.
The plugs were a nice toasty brown, but were severely erroded away. I think first at 35K then every 40K is the correct change interval.
