A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Steering Angle Sensor
Old 04-28-2019, 04:29 AM
Tendai Kufandirori's Avatar
Default Steering Angle Sensor
Hi All.
I am having issues with my steering angle sensor for an Audi A 4 B8 2010 model. This fault is now affecting ESP, ABS and also engine. The sensor itself seems fine but for some reasons I am getting error that the steering angle sensor sub controller is not learned and am getting reading of -800 degrees. Can anyone please help. Please see attached picture. Thank you.
Steering angle readings
Steering angle sensor readings
Thank you for your time.
Old 04-28-2019, 11:00 AM
SMac770's Avatar
Received 1,848 Likes on 1,568 Posts
Have you tried the calibration procedure?
http://wiki.ross-tech.com/wiki/index...el_Electronics
Old 04-29-2019, 08:25 AM
Default Steering Sensor
I have tried to follow that link but the sensor can be calibrated but am still getting the sub controller steering angle recording -800 degrees. I don’t know where the sub controller is?
Thank you,
Kind regards,
Tendai Kufandirori
Old 04-29-2019, 10:44 AM
SMac770's Avatar
It's just part of that same component I believe. Most likely you're going to be needing a new steering angle sensor.
Does the sub controller angle change at all when you turn the wheel? If not, maybe it might be a connector or wire.
Old 05-05-2019, 07:31 AM
No Bozos!
squidix9's Avatar
Default ^^ I was just going to ask the same question
Does the steering angle change when you turn the wheel?
Old 11-12-2020, 03:42 PM
Niall Quinn's Avatar
Default G85 Reading 800 degrees
Thank you,
Kind regards,
Tendai Kufandirori
Hi
i have the same fault, what did you do till fix yours?
kind Regards
Niall
luckymike13
A4 (B7 Platform) Discussion
05-16-2016 02:26 PM
HereInOhio
VAG-COM Discussion
06-12-2014 07:51 AM
Audi S4 Turbo
05-02-2010 07:07 PM
Rob Ad
02-16-2006 10:38 AM
Quick Reply: Steering Angle Sensor
