Stuck on Audi Infotainment System A4 B8 2012
Hello there,
Looking for a bit of a help here.
So recently I just spilled water on the heated seat and basically ruined it.
Took it to a shop and they replaced it with a genuine part and all is working except this thing.
Usually after the car started up, it would start with the Audio Infotainment System then would just continue to the radio - or the last mode it was on.
But now it is stuck on this screen! I can then click on the radio or the power on/off button and everything will work fine.
The other issue it caused is that the home coming/ leaving light is no longer work too even though all the setting is there.
Also the key memory seat is not working as well - as is the key 1 and key 2. the seat memory is still there if I click the button on the driver's side panel.
Let me know if anyone have any idea what could be the problem!
I have vagcom so i can check few things.
Thank you!
The technician said that we can try to re-flash the radio, but it'll cost $160!
Anyone know how to re-flash the radio???
Thank you!
AudiVancouverCanada
05-29-2009 07:32 AM
Most might know this, but the radio turns on without key in ingnition, so no seat belt chime when...
Svart
A4 (B7 Platform) Discussion
10
04-26-2006 05:00 PM
drhaller
04-18-2000 04:21 PM
